Internal Error: "datasupp.cpp" line 3381
Hi everyone,
Can anyone help me out here ?
I'm receiving the internal error named at the subject. It is completely reproducible.
It happens allways when executing the "Search And Replace String"-function, and only then, when I connect to the "Offset"-input of this function a constant value greater than zero (eg. 2000).
I'm running LabVIEW 6.0i on Windows XP.
I need to edit pretty large strings, but by testing this VI with smaller ones, I get the same result.
I'm attaching this VI to the post.
If anyone could give me some advice, I'd be very greatful.
Mamian
(2,422 Views)
Mamian,
what you see here is a bug in LabVIEW 6i that was fixed in LabVIEW 6.1 and it occurrs when the replace string input contains a ' character. If you can't work around this issue the only option will be to upgrade to LabVIEW 6.1 or later.
Jochen Klier
National Instruments Germany
(2,418 Views)
