Inverse Laplace Transform?
Message 11 of 13
(1,488 Views)
I posted improved source code for my Pulse Response Examiner VI that uses the Complex FFT to do a fast inverse Laplace transform.  There are versions for LabVIEW 8.5.1 and 7.1.  Here are the links:
http://automeasure.com/pulse_resp_1_1_source_lv851.zip
http://automeasure.com/pulse_resp_1_1_source_lv71.zip
Joe Czapski
Message 12 of 13
(1,452 Views)
Thank you, it's a good example.  My application is slighlty different, so I hope I can figure out the main features in your vi and hope to re-use it.
Message 13 of 13
(1,389 Views)
