Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results forÂ
Search instead forÂ
Did you mean:Â
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Inverting a Block
Inverting a Block
Davy
Member
‎08-06-2003
09:09 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Normally a block a labview has his input on the left side of the block and the output on the right side. But is it also possible to invert the block in that way that the input is now on the right side and the output is on the left side ?
Greetings
0
Kudos
Message
1
of 4
(3,198 Views)
Reply
Re: Inverting a Block
paul_s
Member
‎08-06-2003
12:25 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I guess you could make your block a sub-vi - make the icon look similar to the function and wire the connector the way you want it
0
Kudos
Message
2
of 4
(3,198 Views)
Reply
Davy
Member
Author
‎08-07-2003
12:59 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I guess that's too much work. I need an easier way.
0
Kudos
Message
3
of 4
(3,198 Views)
Reply
Andrew Tait
Member
‎08-07-2003
08:36 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Davy
wrote in news:5065000000050000001F140100-1042324653000
@exchange.ni.com:
Why do you need to invert the block? Can you give an example of somewhere
that the existing system isn't doing what you want/need it to do?
Andrew
0
Kudos
Message
4
of 4
(3,198 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
