Is ActiveX container equivalent to Automation Open
I have an ActiveX server(say xx.xx) on my machine. When I have an ActiveX container and insert xx.xx, I can successfully call its methods using ActiveX>>Invoke Node. When I use the Automation Refnum on my front panel and select xx.xx, and then use the >>ActiveX>>Automation Open.vi, the ActiveX>>Invoke Node gives me an error.
In both cases, the same methods of xx.xx are available in ActiveX>>Invoke Node. And yes, I am using Automation Close.vi at the end of the VI with Automation Open.vi.
Are both methods not equivalent?
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
(2,581 Views)
I found a knowledgebase article that solved the problem.
S G
(2,562 Views)
Another relevant knowledgebase article here.
S G
(2,561 Views)
