Is LabView 7.0 going to work with a vista system?
(3,248 Views)
Yes, it seems to work ok on my Vista Home Edition laptop. I have done a couple of upgrades to existing Labview 7.0 projects with no apparent problems.
Good luck with your system,
Dave
(3,242 Views)
None of the hardware drivers will work though. You would need to download and install Vista compatible versions.
(3,227 Views)
That sums my problem when i tried vista.I got back to XP after some couple of tries.
(3,216 Views)
Can you elaborate a little more dennis.Will there be some patch which i need to install for the hardware to  work properly?
(3,204 Views)
Hi Kla,
Officially the earliest version compatible with Vista is LabVIEW 8.2.1 so it cannot be guaranteed that it will work although it seems that some people have been sucessful with version 7.
A list of software and driver compatibility can be found here and there is some further information at ni.com/vista.
Hope this information helps and best of luck!
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(3,199 Views)
