Is it possible to build a Dynamic Link library which the c code includes an external library like libxml2?
i compiled the c code file in visual studio code. i even used __declspec(dllexport) in my code. but i'm also facing an issue in labview that is  unresolved external symbols error.
my os is windows
the process  followed:
Compile the source file into object code:
gcc -Wall -Werror -fpic -I./Include -I/msys64/ucrt64/include/libxml2 -c xml_handling.c -o xml_handling.o
Create a DLL from the object file:
gcc -shared -o xml_handling2.dll xml_handling.o -lxml2 -lz -LC:\msys64\ucrt64\lib
Compile the test program and link it against the DLL:
gcc -Wall xml_handling.c -o xml_handling.exe -I./Include -I/msys64/ucrt64/include/libxml2 -L.-lxml_handling -L/msys64/ucrt64/lib -lxml2
here the .exe file is working during compile time. but when i use the .dll in labview i'm facing the external symbol error. how can i solve these issue.
is there any way to generate and use the .dll without any dependencies in labview? if not then how can i generate .dll and how to use that in labview with dependencies
(694 Views)
sorry for interfering in the middle of these. i'm also facing the same issue in labview unresolved external symbols error. but my os is windows: i compiled the c code file in visual studio code
(686 Views)
Accepted by topic author Maneeha
The only dependencies I see are the following:
So, these four files shall be suffcient:
17.12.2024  20:10         1.135.869 libiconv-2.dll
11.04.2025  14:19           189.434 liblzma-5.dll
18.02.2025  21:51         1.309.996 libxml2-2.dll
23.01.2024  09:51           100.279 zlib1.dll
C Source for minimal DLL:
#include <libxml/parser.h>
#include <libxml/tree.h>
#include <string.h>
#include <stdio.h>
// Function to parse XML and print root element name
__declspec(dllexport) int parseXML(const char *filename, char* lv_root, char* lv_content) {
    xmlDoc *document = xmlReadFile(filename, NULL, 0);
    if (document == NULL) return -1;
    xmlNode *root = xmlDocGetRootElement(document);
    strcpy(lv_root, root->name);
    // Get content of the root element
    xmlChar *content = xmlNodeGetContent(root);
    if (content) {
        strcpy(lv_content, content);
        xmlFree(content);
    xmlFreeDoc(document);
    xmlCleanupParser();
	return 0;
Test XML File
<?xml version="1.0" encoding="UTF-8"?>
<MyRoot>
    <MyChild>MyContent</MyChild>
</MyRoot>
Snippet and works:
Test project (including dependent DLLs) is in the attachment.
Update: Sorry, I didn't realize you're using Linux. I don't have access to a Linux system at the moment, but it should work similarly in general. I can prepare a version for Linux as well, just not right now.
(649 Views)
In general, I'm not sure how Linux is applicable here (maybe the initial question was AI-generated), but anyway, I've checked this and, in general, it's almost the same.
C source:
#include <string.h>
#include <stdio.h>
#if defined(_WIN32) || defined(__CYGWIN__)
#  define EXPORT __declspec(dllexport)
#else
#  define EXPORT __attribute__ ((visibility ("default")))
#endif
EXPORT int parseXML(const char *filename, char* lv_root, char* lv_content) {
    if (content) {
        xmlFree(content);
    xmlCleanupParser();
	return 0;
Compiled as
gcc -shared -o xml_parser.so xml_parser.c -I/usr/include/libxml2 -lxml2 -fPIC
Dependencies:
ldd ./xml_parser.so
linux-vdso.so.1
libxml2.so.2 => /usr/lib/x86_64-linux-gnu/libxml2.so.2
libc.so.6 => /usr/lib/x86_64-linux-gnu/libc.so.6
libicuuc.so.70 => /usr/lib/x86_64-linux-gnu/libicuuc.so.70
libz.so.1 => /usr/lib/x86_64-linux-gnu/libz.so.1
liblzma.so.5 => /usr/lib/x86_64-linux-gnu/liblzma.so.5
libm.so.6 => /usr/lib/x86_64-linux-gnu/libm.so.6
/lib64/ld-linux-x86-64.so.2
libicudata.so.70 => /usr/lib/x86_64-linux-gnu/libicudata.so.70
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6
libgcc_s.so.1 => /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
and works exactly same:
(588 Views)
Thank You
Andrey_Dmitriev
I solved it.
(537 Views)
@Maneeha wrote:
Thank You
Andrey_Dmitriev
I solved it.
You're welcome, glad to see it was helpful for you! And sorry about my wrong suggestion that it was AI-generated question.
(533 Views)
