Is it possible to fire Application Builder from an other application
I need to do a lot of things when I want to generate my application in LabVIEW.
Creating a directory
Add all the needed files to build my application
Then rename the directory to be sure the executable application will not find any trace of the directory where it was compiled.
Mathieu Fortin
(2,483 Views)
While I have not had the occasion to use it myself, you might check out this OpenG application builder project.
Remember to read the LGPL license before incorporating the code into commercial software though.
(2,483 Views)
