Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Is it possible to fire Application Builder from an other application
Nitrof
Member
10-28-2002
01:57 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I need to do a lot of things when I want to generate my application in LabVIEW.
Creating a directory
Add all the needed files to build my application
Then rename the directory to be sure the executable application will not find any trace of the directory where it was compiled.
Mathieu Fortin
0
Kudos
Message
1
of 2
(2,482 Views)
Reply
Re: Is it possible to fire Application Builder from an other application
Underflow
Active Participant
10-28-2002
05:08 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
While I have not had the occasion to use it myself, you might check out
this OpenG
application builder project.
Remember to read the LGPL license before incorporating the code into commercial software though.
1
Kudo
Message
2
of 2
(2,482 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
