Is it possible to script event selection for Register Event Callback node ?
I'm trying to find a way to programmatically wrap some ActiveX event registration... using VI scripting.
I'm stuck with a generic GrowableFunction (Generic » GObject » Node » GrowableFunction » GrowableFunction). When just getting AllObjs[] from Diagram, this is the type of reference I get for an already existing Register Evetn Callback node on the diagram. I didn't find a way to use this (I guess) too generic level to select a event to register.
The REG_EVT_CLLBCK.vi diagram looks like this:
I've seen that under GrowableFunction, you can find ObjectFunction and then Contructor, Property, Invoke.
Using theses Property and Invoke class, I'm able to select a property or a method of a already existing node using sripting (you need to allow alternate names).
But I do not manage to get an enought specific class in VI server for the Register Event Callback node.
Is there a trick to select the event to register using VI scripting ?
Or did I reach a kind of dead end ?
Thanks in advance for your help.
(616 Views)
"GrowableFunction" objects have a "Style" property.  In this case, the style is "Register Event Callback".
My guess is that other particulars are stored in tags of the object; but I couldn't find them.
(590 Views)
My other guess is that it's an unexposed property.
An example of that is the bezel color on classic controls.
You can change the color with the "Set Color" tool, but it's not accessible programmatically; not even with this:
(556 Views)
Thanks for your answers. I'll "brute force" properties by index... With some luck, I'll find something interesting to get this programmatic event selection done.
(433 Views)
Here is what I have on that.
(409 Views)
Wow, this is... awsome !! Thank you very much for sharing this.
My 'brute force' investigation did not allow me to identify any other property using this Get/Set Property methods.
And I didn't manage to configure the event to register.
(171 Views)
Hi Mathieu,
I couldn't find a way to set the event either.
Maybe you could post an idea in the Idea Exchange?
I guess this would require to add a new subclass of "GrowableFunction" that would be named "RegisterEventCallback", very similar to class "RegisterForEvents".
Its properties could be:
 - "Event Types": IDs of selected events.
 - "Supported Event Types": names and IDs of all selectable event types for the wired class.
 - "Name Format": no names / short names / long names.
Raphaël.
(138 Views)
