Is there a special driver for the EVAL-AD7799 to get it to work in LabView and if so, where would I find it?
A colleague just purchased this analog devices 24 bit ADC evaluation board and is having some difficulty trying to connect. Any assistance would be appreciated.
(4,203 Views)
It looks like the board comes with a LabVIEW program to interface with it.  Are you trying to develop your own LabVIEW program, or using the one from Analog Devices?  Are you getting any error messages?
Note that you will need the NI-VISA driver to communicate over USB.  The program from Analog Devices probably includes the driver in its installer, but if it doesn't you can download it from our website: http://joule.ni.com/nidu/cds/view/p/id/1070/lang/en
Jeremy_B
Applications Engineer
(4,168 Views)
Hello, I have evaluation board EVAL-AD7799 from Analog Devices, how i undestand Labview must support him. This board  come with driver disk, and on disk existing file:  internal.llb  .. When i open in Labview this file, i see table whith *.vi files. when i try open this *.vi files the mssage that i have: (in attach file "pic1")
please help me with this error, i wont activate this card with Labview.
(3,997 Views)
What operating system are you using?
It sounds like you might have a different operating system then the one the VI was written for.
The other possibility is that you are opening a VI where the block diagram was removed before it was saved.
You might want to contact Analog Devices and see what they have to say.  Maybe they have an updated driver.
(3,981 Views)
Hi
They have removed all or some block diagram. This software can only be run by Labview 7.1. You should contact Analog Devices, and tell them in a nice fashion that this is not very customer-oriented at all. You should ask for a sourcecode which can be compiled. If they refuse you should ask for a refund
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,962 Views)
My operating system is windows xp...
I attach the file internal.lbb from the driver disk, that i can't open in my version of Labview (8.5). maybe you know way to open this file?
when i try to open this file, i have error that i attach in last message.
I have driver with disk  that come with a board.. When i instal this board  i can see him in device manager in my windows, so i tnink that drive is ok..
(3,961 Views)
What else do you want to know. You've already been told that the LabVIEW VI is unusable in 8.6 and the error message gives you the reason. The idiot that made the VI made it impossible for it to be run in a newer version of LabVIEW.
(3,939 Views)
