Is there a way to know which Ethernet port will be used when running TCP Open?
Hello.
I have several Ethernet ports in my computer, and I am trying to write a VI that sends data from one port to the other (for debugging an issue).  I was planning on using the TCP Open and other TCP VIs, but the TCP Open does not seem to have an input to tell it which local Ethernet port I want to use.
So, is it possible to specify which Ethernet port you want your TCP connection to be open on?  How about UDP?
AlejandroZ
(3,041 Views)
The TCP Open does have inputs for specifying both local and remote ports.
Message Edited by Dennis Knutson on 08-23-2007 09:52 AM
(3,037 Views)
I am not sure the local port input really specifies the actual RJ-45 connector you want to use, but rather the "TCP" port, a number such a 3880, and the like.
If you do know that it does allow you to choose the RJ-45 connector, how do you map that u16 to the hardware you want to use?
AlejandroZ
(3,033 Views)
Port means TCP port. If you want to use a specific nic, then that decision is up to the OS. If each is set for a different subnet, then the OS will choose the one based on the address you use with the TCP Open.
(3,026 Views)
