Is there any way that I can recognize which frame is running in the flat sequence ?
Dear all,
I'd like to know whether there is any way that I can recognize which frame is running in the flat sequence ?
If I have five frames in the flat sequence, I want to keep track of each frame in the front panel visually. I'm using LV8.2
Thank you for your reply in advance.
Yoon
Message Edited by swsyoon on 06-26-2009 11:53 AM
(3,145 Views)
Accepted by swsyoon
You could put a local variable in every frame and update that with a constant. Of course, this is really bad implementation and I would highly recommend developing a state machine architecture since what you are doing is NOT the right way to program in LabVIEW. For a template, go to File -> New.. and have a look at the Standard State Machine in the Design Patterns directory.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,136 Views)
This can be done easily several ways, I say have an enum, or just a numeric indicator, with local variables in each state of the structure.  In the first case write a 1 to the indicator, the second one write a 2, and so on.  Then when you program gets to that part of the code the indicator will be updated displaying what frame it is in.
(3,132 Views)
Thank you very much for your replys. It helps a lot.
Yoon
(3,129 Views)
