Issue copying code form one vi to another
Hello Everyone,
i faced issue while copying code from one Vi to anther vi, the code  was copied but not shown in vi front panel as well as in block diagram ill try many times but issued still remains same. i have a code in another project vi but i want to copy and integrate this code to another project vi.
i need help in this regards,
thanks in advanced...
(2,824 Views)
hello.
I think the controller is out of sight.
Look for it in Find Control.
/* HANAMARU */
(2,818 Views)
hello @hanamaru
issue is that the block diagram side as well as front panel side both are invisible that why i am unable to find the controls of the code...
(2,816 Views)
Display the navigation window and click on it.
/* HANAMARU */
(2,809 Views)
Accepted by Aht22
 How do you know it's "copied" if you can't see it anywhere???
One possibility is that your code is gigantic and you are outside the valid coordinates (see also).
Can you attach some code (e.g. the "another VI" containing, but not showing, the copied code)?
How do you Copy? (drag selected code? ctrl+c/ctrl+v? right-click subVI replace with contents? Some other way?)
(2,746 Views)
Is this a serious Post?  If you really have a LabVIEW VI that "is invisible" and you want us to help you to "see it", you need to attach your VI.  Otherwise, the most reasonable explanation of why the copied code is not visible is that the original code "is not visible" and not really LabVIEW code.
Hmm, invisible code -- what a great idea!  I could write a wonderful LabVIEW routine in "Invisible Code", and not worry about anyone "stealing my Intellectual Property" because ... it's Invisible ...
(2,721 Views)
