Issue with cluster and arrays.
I am trying to create a program with a "ring" in order to be able to act as a case structure later on. But I want the values from the "ring" to be read from an excel file so I can add cases without having to modify the program.
Since I am just starting to play with it I created and excel with 3 columns. First column is the ring item, second column is the ring value, and the last 2 columns are just first name and last name.
I worked out the logic that I think could work. But unfortunately I have an issue with the output result because of the type of date. In order to use a property node on the ring to modify the values and items (stringsandvalues) it must be a 1D array of cluster of 2 elements. I have the 2 elements and when I use bundle I get a cluster of 2 elements with 2 of the 1D arrays. The program doesn't like this so it wont run.
Thanks for all the help and ideas.
(2,335 Views)
You have it backwards.  You have a cluster of arrays.  You need an array of clusters.  Try using Build Clusters Array instead of the Bundle.
(2,324 Views)
Thanks for your response. I tried using build clusters array but it doesn't work either because its two different types of data. Any idea on how to fix this??
(2,284 Views)
Accepted by josear04
Hi Jose,
use IndexAndBundleClusterArray instead:
(2,279 Views)
Thanks a lot. It worked perfectly.
(2,265 Views)
