It is possible to update a type def or strict type def constant during runtime?
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 1 of 19
(3,602 Views)
no
That's effectively asking an application to change its own code.
Message 2 of 19
(3,596 Views)
I am on the same side a Saverio but I have to ask,
"What is the Use case that you want to use that technique to solve?"
Tell us what your challenge is and we may be able to give you some hints.
Ben
Message 3 of 19
(3,586 Views)
Thanks Ben and Saverio for the reply.
I Have a parameters list and its limits in a file. I want to access the particular parameter limits (I tried to use Ring menu and populate the parameters list from the file). I wired a menu constant in my block diagram to get the parameter Index, If I modify the file I want to automatically update the menu constants. Here I got struck.
Balaji PK (CLA)
Message 4 of 19
(3,524 Views)
Do you need it to update when you edit the file or the next time that you open the program? Is it ok to push a button after the file is updated or do you need it to be automated?
Tim
GHSP
Message 5 of 19
(3,515 Views)
I dont want to have any manual intervensions. I want to update the type def control with the latest parameters available in the file.
I want to have a function global with the cases Update Limit parameter table and get parameter Limit, so during lauching my programme i will update the parameters and keep all the datas in the shift register. when ever the user wants the particular parameter limit, i will get by wiring a ring constant in the block diagram.
Balaji PK (CLA)
Message 6 of 19
(3,510 Views)
The "ring" requirement is an issue. The strings in a ring are just fancy labels used the GUI but they don't come along with the ring.
A "Type def'd Enum" will cary the values and the text but sparse enums are not allowed.
Are there gaps in you data or could you use an enum?
Ben
Message 7 of 19
(3,503 Views)
Well, you can't do this, so let's move along, shall we? Smiley Wink
From what you're describing it sounds like you need to use strings, and not an enum.
Message 8 of 19
(3,502 Views)
After thinking yes I agree.
Create an Action engine to allow the updates and get the value. If you create a sized-down wrapper for each value you want, it can look very similar to a ring in the code.
THe Read operation could use an enum to select which value you want from an array populated at Init time.
Ben
Message 9 of 19
(3,489 Views)
Thanks for the reply. Do you have any Ideas or sugessions achieve the task. I attached the snapshot for better understanding of my requirements.
16979iE4DCDD5769843924
Balaji PK (CLA)
Message 10 of 19
(3,481 Views)
