JSON conversion
{"channel":{"id":720151,"name":"Power Monitoring System","latitude":"0.0","longitude":"0.0","field1":"Voltage","created_at":"2019-03-05T10:24:13Z","updated_at":"2019-03-05T10:24:13Z","last_entry_id":523},"feeds":[{"created_at":"2019-03-07T11:16:17Z","entry_id":523,"field1":"056"}]}
Hello friends,
I'm trying Unflattering from JSON , i dont know how to get the data from it, i need the value of "field1" please kindly suggest a method or send me the VI.
Message 1 of 8
(6,192 Views)
Hi Rao,
A very simple way:
Message 2 of 8
(6,177 Views)
what about 'unflatten from JSON' in the String Function Palette??
Function>Programming>String>Flatten/Unflatten String>...
Regards
Kay
Message 3 of 8
(6,173 Views)
value of field1 is 56
so i need to extract the value of field1 from JSON file
Message 4 of 8
(6,161 Views)
Accepted by topic author MrRao
Try using JSONtext.
Message 5 of 8
(6,143 Views)
it worked ,
Thank You for suggesting the addon , its simple to build..
Message 6 of 8
(6,133 Views)
What's wrong with the inbuilt LabVIEW JSON parser?  Do you really need a plugin for such a simple operation?
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 7 of 8
(6,072 Views)
For the very simplest example, no, but the complexity of using the inbuilt parser grows rapidly with only slightly less simple real world problems.
Message 8 of 8
(6,026 Views)
