Keithley 2700 RS232 Multiple Channel Help needed
Replace "Read Data Buffer Subset.vi" by "Read Multiple Direct.vi".
"This VI initiates a reading, waits until data is available, and returns that data.  The data is output directly to the bus instead of storing the data in the instruments internal data buffer."
Message 21 of 31
(2,762 Views)
Thanks for your support Jean-Marc!
I want to use my Keithley 2750 with a 7703 to obtain a maximum channels/second. In this moment I am using a .vi with a "Read Multiple Direct.vi" (please see the attachment), but I can only read 37 channels / second.
Thats why I want to use the "Read Data Buffer Subset.vi", with this I expected to obtain an improvment.
Many thanks.
Message 22 of 31
(2,740 Views)
I am not familiar with the express vi "Write to Measurement File", but you could separate yours data like this:
It seems for me than you could read about producer - consumer:
https://decibel.ni.com/content/docs/DOC-2431
Message 23 of 31
(2,721 Views)
Hey friends ,
I have the exact same problem , i am using same program. I have two thermocouples while reading two channels after certain the readings from the channel 2 is transferred to channel 1 and its changing after some period of time. I don't understand what did i do wrong . I am attaching the vi and excel file screenshot . Thank you in advance.
Message 24 of 31
(2,145 Views)
Hello Sinivasan648!
After downloading the VI I was unable to see many of the attached VIs. What was the driver that you used in conjunction with the rest of the code? How are you verifying that the temperature readings are switching over? Do you have one thermocouple very warm and the other very cold? About how long does it take for the values to switch over?
John H.
Applications Engineering
Message 25 of 31
(2,124 Views)
We are using the device Keithley 2701 and yes i have two different temperatures ( i differentiated one with hot water ). as you can see in the excel file after 147 ( temperature of two thermocouples are swapped)  the reading is switched over. It happens like that and i have attached the zip file where all the basic vi associated with the file are located. Thank you of the help. hoping to get some assitance to resolve this problem.
Message 26 of 31
(2,110 Views)
This is very odd behavior. How often does it occur and what steps do you take to reproduce this?
Dale S.
RF Systems Engineer - NI
Message 27 of 31
(2,092 Views)
Hi Dale ,
Yes ,its very odd for me too. It often occur at some intervals and intervals doesn't seem continous. It's difficult for me to understand why it's happening. It would be helpful if someone can help us resolve this. Thank you
Message 28 of 31
(2,090 Views)
Hi Dale ,
Message 29 of 31
(2,090 Views)
My best guess would be that there is some sort of race condition where the instrument is not processing calls from the instrument driver in the correct sequence.
Dale S.
Message 30 of 31
(2,081 Views)
