Keithley 2700 RS232 Multiple Channel Help needed
Hello Dale ,
Thank you for your reply. i tried different program with single channel and it works perfectly for single channel. but when i try to read two channel this problem occurs. So i was thiking there should be something in the program that causes this. I am not sure. But if the problem is with the instrument ? do you have any idea how i can verify it ? That would be really helpful. Thank you
Message 31 of 31
(553 Views)
