 psmorris
			psmorris
			06-15-2014 08:27 AM
Ignore my last post - its as easy as finding the correct port number in the manual (23 seems to be default for the AKDs) and then just sending (for example) MOTOR.TEMP as a string with the standard TCP/IP VIs... for a minute I thought it was going to be much harder than that!
Cheers
Paul
 k-usa
			k-usa
			11-26-2014 07:05 PM
Hi
i am looking for simple example to use the AKD via ethernet
Thank you for you help
 nonecure
			nonecure
			12-01-2014 09:48 AM
I posted full functioning code on page 2, did that not suit you needs?
 k-usa
			k-usa
			12-01-2014 10:45 AM
Hi
thank you for you help ,
But i need only ethernet cable , do you think is possible to use you example ?
 nonecure
			nonecure
			12-01-2014 11:15 AM
That is how I am using it.
 k-usa
			k-usa
			12-01-2014 11:42 AM
I tried you example but some file missing , Modbus file , below the project :
 nonecure
			nonecure
			12-01-2014 11:51 AM
you will need to download the Modbus drivers off of the NI website.
 k-usa
			k-usa
			12-01-2014 02:13 PM
yes i did and i tried the Kollmorgen Servo request.vi , where do i have set the IP adresse [ adresse of Driver ] ,
How can use this example ?
thank you very mush for you help .
 k-usa
			k-usa
			12-02-2014 03:29 PM
Finaly i used TELNET protocol is easier and it is working
 mindmaster54
			mindmaster54
			10-29-2015 10:27 AM
Were you ever able to figure this out? I am working on a program that links multiple task toghter and I cant seam to get the mt.mtnext address right.
