Kollmorgen AKD communication with Labview Ethernet/IP drivers
MajTal,  This thread if for questions about talking to the Kollmorgen drive, please create another thread if you have other questions like DAQ requirements.
I said earlier that you don't need any hardware to talk to a Kollmogen drive, the Ethernet port on the PC will comminicate to the Ethernet port on the servo drive.  How many times do I need to post the same answer before you are sure?  It sounds like you are in over your head on this project.
Message 31 of 60
(3,844 Views)
I am so sorry.
Message 32 of 60
(3,839 Views)
hello ,
thank for the VI's
but i want to know how you find the addresse in hexa
for example : the command "enable" ==>  0000 0000 0009 0110 00FE 0001 0200 01
because i want to create others commands ( like MT.ACC , MT.DEC , MT.CNTL , MT.V)
thank a lot
Message 33 of 60
(3,800 Views)
On the 2nd page I provided a vi to convert to hex.
Message 34 of 60
(3,782 Views)
I'm sorry but I don't understand your answer
Which is Vi which converted to hex
I would like understand where you find the information to convert text command ( MT.ACC , etc) to Hex command TC/IP
thank
Message 35 of 60
(3,767 Views)
The "Convert Modbus command to String.vi" (it uses the "MB Modbus Command to Data.vi" subvi), will take your modbus commands and convert them to the hex string.
Message 36 of 60
(3,757 Views)
thank ,
it's ok to convert but which document can I find the informations of Starting address , quantity and data.
Message 37 of 60
(3,754 Views)
Go to Kollmorgen's website and download the user manual.  There is a section that has all the modbus commands that you are looking for.  It's been a long time since I have worked with it, but I think you also have the commands in the Workbench software.  I think I remember the help in the software being a good source for the commands.
http://www.kollmorgen.com/en-us/products/drives/servo/akd/
Message 38 of 60
(3,750 Views)
I found the list of the parameters with their addresses
can you explain to me how to fill VI "convert Modbus to string" with the MT.P command
 MT.P
because , when I send "0000 0000 0009 0110 0226 0004 0801 68" ,  I lock the Drive
I don't send a other command
thank
Message 39 of 60
(3,737 Views)
Interesting discussion on this. I'm using the AKDs for a project and was just wondering if there's a quick and simple way to use ethernet or tcp/ip etc to query a couple of parameters on the drive? I only really want motor temperature and maybe fault code.
I dont really want to be buying the NI Ethernet/IP driver and hoped I could do something simple with the TCP/IP VIs...
Any help greatly appreciated!
Cheers
Paul
Message 40 of 60
(3,645 Views)
