Kollmorgen AKD communication with Labview Ethernet/IP drivers
Ignore my last post - its as easy as finding the correct port number in the manual (23 seems to be default for the AKDs) and then just sending (for example) MOTOR.TEMP as a string with the standard TCP/IP VIs... for a minute I thought it was going to be much harder than that!
Cheers
Paul
Message 41 of 60
(4,210 Views)
Hi
    i am looking for simple example to use the AKD via ethernet
Thank you for you help
Message 42 of 60
(4,121 Views)
I posted full functioning code on page 2, did that not suit you needs?
Message 43 of 60
(4,099 Views)
Hi
  thank you for you help ,
But i need only ethernet cable , do you think is possible to use you example ?
Message 44 of 60
(4,087 Views)
That is how I am using it.
Message 45 of 60
(4,079 Views)
I tried you example but some file missing , Modbus file , below the project :
Message 46 of 60
(4,071 Views)
you will need to download the Modbus drivers off of the NI website.
Message 47 of 60
(4,061 Views)
yes i did and i tried the Kollmorgen Servo request.vi , where do i have set the IP adresse [ adresse of Driver ] ,
How can use this example ?
thank you very mush for you help .
Message 48 of 60
(4,055 Views)
 Finaly i used TELNET protocol is easier and it is working
Message 49 of 60
(4,031 Views)
Were you ever able to figure this out? I am working on a program that links multiple task toghter and I cant seam to get the mt.mtnext address right.
Message 50 of 60
(3,803 Views)
