LABVIEW 2013 POP Email
Hi All
I am looking for the example to retrieve an email from gmail (pop.gmail.com or Outlook). i have already downloaded the example https://decibel.ni.com/content/docs/DOC-26470 i got an Error -2147024156 occurred at The requested operation requires elevation.
I am using labview 2013 and outlook 2007.
Please give me some advise !
Best Regards
Luong.Tran
Message 1 of 8
(4,819 Views)
Hey Tran,
This error you said is this ??
 Server not available. Outlook error 2147024156. - Microsoft Community
http://answers.microsoft.com/en-us/office/forum/office_2007-outlook/server-not-available-outlook-err...
I could not find this error code in LabVIEW.
I think this error is not caused by it.
You should look for Microsoft thread for more information.
Tepig
GCentral
Message 2 of 8
(4,810 Views)
Accepted by topic author Luong.Tran
This might be related to the User Account Control Settings (UAC), a posible solution to your issue is to change the UAC level using the following method:
(1) Start button
(2) Search "uac" and hit enter
(3) Change the UAC level to the lowest of the 4 levels
(4) Restart computer
(5) Run VI
Let me know if that solve your error.
Camilo Triana
Account Manager
camilo.triana@ni.com
Message 3 of 8
(4,778 Views)
Hi Tepig and Camilo
The problem is solved when i use outlook 2010.
Thanks and Regards
Luong.Tran
Message 4 of 8
(4,760 Views)
Hi All
How can i retrieve the attachment file from outlook using activeX?
Does anyone have an example code or any suggesttion?
Luong.Tran
Message 5 of 8
(4,719 Views)
Hi Luong.Tran
In order to keep our forum database organized, anytime you have a question of a different subject please feel free to create a new forum.
Camilo Triana
Account Manager
Message 6 of 8
(4,700 Views)
Hi AEs
Please see the new subject !
http://forums.ni.com/t5/LabVIEW/LabVIEW-Retrieve-Attachments-File/m-p/2738572#M809589
Luong.Tran
Message 7 of 8
(4,691 Views)
Hi AEs
Would you please help me to check the code as the links below!
http://forums.ni.com/t5/LabVIEW/LabVIEW-Retrieve-Attachments-File/m-p/2739784#M809821
Luong.Tran
Message 8 of 8
(4,640 Views)
