LINX 3.0 - LabVIEW for BeagleBone Black and Raspberry Pi 2/3
Hi Sam ,
      I tried to install Linx with LabVIEW 2017, and I got everything fine upto adding a device in a Linx target configuration.
      But when I create a LabVIEW project I can't add any device named linx target in both existing device list and new target list what can I do to rectify this?
                 Advance thanks..😃
Message 71 of 82
(5,079 Views)
Deploying to targets like Pi and BeagleBone is currently limited to LabVIEW 2014, here is the text from the LINX FAQ:
Which versions of LabVIEW is LINX compatible with?
LINX Remote I/O (Arduino, chipKit, etc) is supported in LabVIEW 2011 or newer and the 32-bit version of LabVIEW is highly recommended.
LINX Local I/O (ie deploying to BeagleBone Black and Raspberry Pi 2/3) is only supported in LabVIEW 2014 SP1 (32-bit).
Message 72 of 82
(5,062 Views)
Good evening hooovah,
     I try to download LabVIEW 2014 but I redirect to download 2017 only is there any way to get 2014?
Message 73 of 82
(5,048 Views)
I think this is what you want.
https://www.ni.com/en/support/downloads/software-products/download.labview.html#306311
For future reference you can go to ni.com/download and find all NI software.
Message 74 of 82
(5,044 Views)
Yes Exactly  thanksss.
Message 75 of 82
(5,037 Views)
Anything in the pipeline to support newer versions of LV yet?
Message 76 of 82
(4,948 Views)
How fast we can read from AI in BeagleBone? I used a loop for reading the AI by "Analog Read 1 Chan.vi", but it's too slow! How can I read it fast in the individual task a write to a FIFO or dual memory continuously and then use it in the another task?
Best regards
Hamid Naghizadeh
Message 77 of 82
(4,840 Views)
Hi Hamid,
The speed of AI reading is going to be determined by the speed of the Beaglebone Black onboard sampling clock and the speed at which your LabVIEW loop is running. Are there any delays in the LabVIEW loop?
What do you mean by slow? What speed are you currently acquiring data?
Best
Alex
Hardware Engineer
Message 78 of 82
(4,823 Views)
Thanks Alex,
I think that ADC sub-system sample time is about 15 ADC clock cycles (at 24MHz (typ) it will be 41.6nSec per cycle) results into about 625nSec . And there is FIFO and DMA to read the ADC, But unfortunately I don't know how to use them in the LabVIEW. Is there any project example in LabVIEW to work with those features?
Best regards
Hamid
Message 79 of 82
(4,818 Views)
Hi Hamid,
I'm unfamiliar with the Linx functions specifically, but they should be called similarly to how DAQmx functions are called.
This video outlines how to create a simple DAQmx analog input:
https://www.youtube.com/watch?v=7XNv-BeQ99A
This is the function you should be using to read in an analog input signal:
Analog Read 1 Channel
https://www.labviewmakerhub.com/doku.php?id=learn:libraries:linx:reference:labview:analog-read-1-cha...
You can also check the examples within LabVIEW if you've already installed LINX.
Open LabVIEW > Help >  Find Examples
Check for a "LINX" folder or open the "Hardware Input and Output" folder and look for "LINX" in there.
Again, not very familiar with LINX, but the corresponding LINX functions should be called in a similar way to how the DAQmx functions are.
Alex
Hardware Engineer
Message 80 of 82
(4,813 Views)
