LINX 3.0 - LabVIEW for BeagleBone Black and Raspberry Pi 2/3
Hello!
I'm late to the discussion, but still...
Is there any support for BeagleBone Black Wireless.
If it's supported, how do  I connect BeagleBone for 'LINX Target configuration'?
Message 81 of 82
(1,459 Views)
@Gurator, I'm also interested in the answer.
searching for "labview wireless" in the forum https://beagleboard.org/discuss , I found the following post named "Wireless connection on the BeagleBone Black Wireless does not work.". To me nothing is indicating that the BeagleBone Black Wireless is not supported, the user just had network connectivity issues as he was not even able to ping.
Greetings,
Black Beaglebone Card and computer have connectivity problems
Internet access is required to install lab run time. And the possibility  to work the Linx tool on the Beagle card.
The image suggested by the manufacturer can not be updated.
The "Linx Target Configuration" of labview appears that it does not have internet access. The usb connection between the computer and the card works then  using  it by installing the setup wifi,  it connects to a wifi network,    but does not respond the command "ping www.google.com"
thanks for your advice
Message 82 of 82
(1,438 Views)
