LV and multi-core, acquire data with DAQmx on dual-core
Hi all,
The affinity is set for the two CPU; if I run CPU Test.vi the CPU usage is 50% (20% of the first, 80% of the second).
For the acquisition I used timed loop; is it better put some delay or "offset/phase"? I've tried to put in one loop 5ms of offset but nothing change.
There aren't produce/consumer pattern but only the default buffer of the DAQmx; I wait for the data in "sleep mode" (1 sec).
I attach an image of the task manager: ACQ in "PAUSE" is when I got the problem and I don't received data; after, when the acquisition "restart", the "available samples" increase a lot.
I don't use USB device but two PXI card with fiber connection to the PC (8336)
Message 11 of 19
(1,358 Views)
I am not sure it is cause by the usb driver
the cause is may be the cpu having on other priority
and not listening,
Could you check in the task manager,
Message 12 of 19
(1,354 Views)
I was not finishes,
check the task manager on the processus tab and
sorted by process (greater first)
when the cpu load at 100% occurs, look to see
the process that consume cpu time
and get the result back
Jacques
Message 13 of 19
(1,351 Views)
Hi Jacques,
in the process list I see that Labview is the process that use much CPU, 50% of the total (100% on one core, 0% on the other)
thanks
Message 14 of 19
(1,318 Views)
I don't know if you're investigated the possibility of USB problems, but a sudden "loss" of a USB device can also cause a program to block one core of a dual-core processor (retrying the communications).
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 15 of 19
(1,307 Views)
finally I have try to use LV 8.2.1 to compile my application.
Probably there was a problem of synchronization and thread-switch between timed loops.
Now it works fine also with dual-core PC.
Thanks a lot for all helps.
Message 16 of 19
(1,231 Views)
Hey Michele,
Thanks for the follow up! I'm glad everything is working for you. Now with the release of LabVIEW 8.5, I would encourage you to give it a test run as well!
Happy Programming!
Jordan Randall
National Instruments Italy
Message 17 of 19
(1,213 Views)
Hi Jordo,
I'm waiting for the delivery of the 8.5 to test my appl.
I've seen that there's support for multi-core processor.
Thanx
Message 18 of 19
(1,203 Views)
I have a similar problem with dual core Athlong 64 4200 machines on ASUS AV8 mainboards.  I have PCI-6251's to acquire data.  There is definitely a timing problem in DAQmx when used with fast dual core mahcines.  This is simply continuous simultaneous acquisition and generation on ao0 and ai0.
The 6251 is plugged into a CB-68 with nothing connected.  Normally I should just be picking up white noise and some coupling from the ao, but every so often I get those huge noise spikes.  They aren't there if I run the same code on a single core machine.  Also if I go in the BIOS and set the CPU speed to 1500MHz instead of 2100MHz the problem goes away.  The spikes are smaller if I connect the acquisition channel to a lower source impedance, but they are still there on the order of several millivolts even if I short the ai to ground.
-Devin
I got 99 problems but 8.6 ain't one.
Message 19 of 19
(1,142 Views)
