LV text rendering, MBCS, OS, Unicode
I'm pretty sure there are people using CP1251 out there. Either they gave up, or they solved this problem. Would be nice to get some insight from them.
Message 11 of 16
(1,057 Views)
@pawhan11 wrote:
Smiley Happy
Would be easier to drop LV and do pure c#  Smiley Happy
Not for me. 😛
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 16
(1,056 Views)
I have tried other things but no luck.
Maybe this is related to LV installation?
Message 13 of 16
(1,044 Views)
Hi pawhan11,
I tried different way to do a unicode conversion for UTF16 which works fine till U8, Finally i went with Excel  VB macro function and embedded in LabVIEW to RUN Macro and read back Unichar Values from excel
Message 14 of 16
(1,038 Views)
Thanks for reply.
Unfortunately installing excel on all possible machines is not an option only to provide translation.
I no longer work on this project but it would be nice to find solution, or logical explanation why this does not work. i will give it another try with clean os and clean LV on other pc.
Message 15 of 16
(1,005 Views)
Excel has a exact function for Unicode Conversion, whereas LabVIEW is not supporting even when Unicode= True is given in LabVIEW.ini.
LabVIEW Works fine if your Unicode is U8.
Message 16 of 16
(1,001 Views)
