LVOOP Class Process Data Bug?
Man, my very own bug!  This feels like a coming of age tale.
Message 11 of 18
(2,860 Views)
I don't know if Ben is using 8.5 or 8.5.1, but I opened in 8.5.1 and it worked just fine.  I opened the control and Readback VI, and when I changed Max Flow to Max flow 1, the change propgated.
Message 12 of 18
(2,851 Views)
Accepted by JeffOverton
Looking at the 8.5.1 bug fixes, Item 4AKFM1J1 is the exact problem you are having.
Message 13 of 18
(2,844 Views)
Jeff, Congrats on your first bug (found, not created!)
I really like LVOOP but bugs like these scare me a bit.  I have other problems at the moment with private class data corrupting consistently.  This has to do with using 8.20 also (see below) but it's hair-raising at times.  I'm mass compiling every 20 minutes to try to catch these sneaky corruptions.
Don't get me started on trying to build an application with LVOOP.......
It also re-affirms the old rule of thumb of not working with .0 versions of anything.
I'm working in 8.20 for a customer. They don't want to *risk upgrading to 8.2.1*.  :smileymad:  It crashes a lot.
I used LV 6.1 a lot.  Skipped 7.x altogether.  Used 8.2.1 extensively (and now realise how much better it was compared to 8.20).  Will likely move to include 8.5.1 soon.  Patiently awaiting 8.6.1.  Have resisted the urge to even install 8.6.0.  I was kind of bemused to see the CDs actually labelled 8.6.0.  Makes you automatically eager for the new release.
Shane.
Message 14 of 18
(2,839 Views)
So I don't suppose it's free to upgrade to 8.5.1?
Message 15 of 18
(2,812 Views)
No, unfortunately the 8.5.1 upgrade is not free.
Message 16 of 18
(2,790 Views)
If you purchased 8.5, then 8.5.1 would be provided automatically via SSP update. If you purchased an earlier version of LabVIEW and then received 8.5 as an update, it's possible your SSP subscription expired prior to the release of 8.5.1, in which case you would need to renew your subscription to get the update.
Roy
Message 17 of 18
(2,762 Views)
Roy
Thanks Roy, I'll have to ask our license manager about this.  I'm pretty sure she bought 8.5.
Message 18 of 18
(2,744 Views)
