02-10-2016 04:42 PM
When using the "web-based installer" in a VirtualBox VM, I was happy to finally see the % complete get to 100%.
Then it just kept going. Worried that I would run out of room in the VM, I cancelled the operation.
After resizing the VM, I started the process again. It finally ended around 140%.
This screenshot was from the first attempt:
steve
02-10-2016 05:06 PM
This has been seen before (search the forum). I think the answer was that the apparent size shown is what the installer thinks it should be and there is a disconnect between this and what the size actually is.
02-10-2016 07:35 PM
You went to plaid!!!
02-10-2016 08:15 PM
I have no idea what could have happened but does LabVIEW work after finishing installing?
02-11-2016 12:09 AM
well you got a lot for you money, be happy! ![]()
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
02-11-2016 01:29 AM
Maybe the NI installer team are fans of Spinal Tap?
02-11-2016 01:52 AM
Matt,
Yes - based on limited testing, it appears to work.
I did not see this issue when installing LV 2012 or LV 2013 in VirtualBox.
This install did have Signal Express which was was not in the other installations.
steve
