LabVIEW 2024Q3 dialogs not running when opening
A number of dialogs of in-built functions like e.g. Clear Object Cache, Profile Buffer Allocations etc. open when I select them, but they are not running. I can click on the run-button to get them to work, but why is this happening? I have seen this in 2022 as well, but now it also shows in LabVIEW 2024Q3.
(1,060 Views)
I've never seen this before, it's very strange. I can't think of any reason this would happen other than something being corrupted in LabVIEW.exe itself or its resources files.
(1,017 Views)
Accepted by Mads
There is an option under Security tab to *not* run vi's when opened. Uncheck that and everything will go back to normal. 🤓
Former Certified LabVIEW Developer (CLD)
(1,010 Views)
Hehe, I thought you were just joking @Frozen, but no - that actually fixed it.
I would expect internal functions to always be whitelisted...but there might be something corrupted in there as well, because when I changed the security setting to allow VIs to allow VIs to run when opened it gave an error:
It still had an effect (now the dialogs run when opened) though.
Opening the whitelist json-file also gave me an empty file.
(1,001 Views)
Wow, I learned something new about LabVIEW. That definitely does *not* happen every day. 😉
(997 Views)
Something else that doesn't happen every day: A declined idea got implemented.
(987 Views)
