LabVIEW 8.6 DVD Internet Activation Error
Has anyone else had dificulty with the above?
The error "NI Activation Wizard - Activation Error" Retry, Other or Exit
Activation from CD's has always been OK .
Regards
Andy Vessey
Message 1 of 12
(5,184 Views)
Hi Andy,
The activation server was down yesterday so it might have given you an error because of that. Try again today and let us know if it still doesn't work out. Also, here is another way to activate:
Product Activation and Licensing
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 12
(5,159 Views)
Hi Adnan,
Thanks for the reply and advice.
I have just tried the internet activation again it it still fails in the same way.
Our IT people say nothing has changed here with respect to this (but who knows what they get up to!).
There are other methods of registering I know, but this method has always worked form me. We have several developer suites here to register with many products so the internet is easy. Others here are having the same problem
Internet registration has only stopped working on NI/LV8.6 etc going to DVD, so thought some feed back may be needed.
Any other thoughts - have people had this working?
Regards
Andy
Message 3 of 12
(5,132 Views)
Hi Andy,
Have you tried activating atleast one of the licenses with the other activation systems?
If that doesn't work, I would wonder if the system has rolled over your Dev Suite to version 8.6.
In any case, I would recommend that you contact customer services at 01635-523545 if you are based in the UK. If you are based in any other country, let me know and I could provide you with a number for that location.
Message Edited by Adnan Z on 09-02-2008 03:16 PM
Adnan Zafar
Message 4 of 12
(5,130 Views)
Hi Andy,
I just wanted to follow up and see if you were able to activate the product successfully. If you were able to do so, can you please let us know how you resolved the issue, so the entire community benefits? Have a great weekend!
Adnan Zafar
Message 5 of 12
(5,090 Views)
Hi Adnan,
No not resolved. I had to resort to the second level of activation.
You didn't let me know if others have been sucsessful in top level registration from the new DVD set?
Regards
Andy
Message 6 of 12
(5,071 Views)
Hi Andy,
I haven't heard of any problems with DevSuite DVD activation. I would recommend that you contact your local NI branch and let them know of the issue (since it not working for a lot of people in your company is a serious issue). If you are based in the UK, you can call us at 01635-523545 and refer to service request 700644.
Adnan Zafar
Message 7 of 12
(5,046 Views)
I got the same problem.
Best Regards.
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 8 of 12
(4,912 Views)
I just had this same problem as well.  I just bought a new PC with Vista Home Premium.  I installed LabVIEW w/DSC and Real-Time from my Dec 08 Developer's suite update.  The Internet Activation method failed.  I was able to use the alternative method of using the web page and copying the generated activation codes from the web page to the License Manager.
Is this a problem caused by Vista?  I did not have any popups asking for permission to go through the firewall to get the codes.  I never had an issue with my previous home PC which was XP, nor my work development PC and PXI box which are also XP.  Worst case, XP might pop up a dialog box asking if you want to allow access through the firewall and allow National Instruments software to be on the approved list.
This has been my first experience with Vista.  Not too bad so far.  It looks a bit different.  Some things are prettier, some things uglier.  They've buried some of the advanced user features that I knew how to find in XP.  (Why is My computer icon missing on the desktop by default?)  But Google is my friend to figure out how to get things set up right.
Message 9 of 12
(4,768 Views)
I don't have tested last updated DVD, but when I got problem, I was using Windows XP (Don't sure about SP2/SP3).
Best Regards.
Luis A. Mata C.
Ing. Electrónico
BBM Pin: 2B83E99A
Thanks: Kudos
Message 10 of 12
(4,754 Views)
