08-25-2008 08:53 AM
I was wanting to upgrade to 8.6 but noticed that my rep gen toolkit(1.1.1) is not compatible.
Will NI be offering a free upgrade? or do I have to go to management and ask to purchase rep gen toolkit 1.1.3 for 500 US dollars? Purchasing the same toolkit every few years when you have an SSP for a full development system is getting kind of old.
08-25-2008 09:40 AM
I think you can install the old toolkit to the new LabVIEW version, VIs are still VIs, it's just that new release of the toolkit has changed but the upgrade should be normal.
If you have a (professional?) SSP the toolkit will be included.
I would just try to see if the toolkit is installable on 8.6.
Ton
08-25-2008
10:38 AM
- last edited on
08-04-2026
04:56 PM
by
Content Cleaner
I tried installing 1.1.1 with LabVIEW 8.6 and it did not work. The report generation VIs were rewritten using classes.
The document below says to Not Install report generation toolkits 1.1.2 and below with LabVIEW 8.6.
http://digital.ni.com/public.nsf/allkb/C7CF35C4F545FFBE8625745D0080EBAE
08-26-2008 04:50 PM
Hi Brian,
There is no way to upgrade for free over the internet. This sounds like a great question for one of our sales representatives. I would encourage you to call us at 866.ASK.MY.NI.
Let me know if you have anymore questions.
Dan Richards
08-26-2008 09:47 PM
The LabVIEW 8.6 Platform DVD includes the installer for the Report Generation Toolkit 1.1.3, which is the only version of the Report Generation Toolkit that will work with LabVIEW 8.6. I'm pretty sure that your RGT 1.1.1 serial number will activate RGT 1.1.3, but you'll want to double check with your sales rep to be sure.
-D
P.S. - Going forward, old versions of toolkits will not be compatible with new versions of LabVIEW. This is because each toolkit on the LabVIEW Platform DVD will only install to the LabVIEW version on the DVD...this allows you to have multiple toolkits installed on your machine at the same time, which has been a long-requested LabVIEW feature.
08-28-2008 07:27 AM
Report Generation Toolkit 1.1.3 is available for download if you have a SSP.
My 1.1.1 serial # was able to activate 1.1.3, so I am now up and running with 1.1.3. ![]()
Thanks Everyone,
08-31-2008 08:23 PM - edited 08-31-2008 08:23 PM
Can anyone point me towards the V1.1.3 download link for SSP users?
Thanks.
09-02-2008 05:59 AM
I believe that V1.1.3 only works with LabVIEW 8.6, and the toolkit is on the 8.6 DVD.
09-02-2008
01:18 PM
- last edited on
08-04-2026
04:56 PM
by
Content Cleaner
If you are an SSP customer then you should be able to access the Service Resource Center in order to download any of the software updates that you need. If you have any further questions please just let us know!
09-02-2008
05:52 PM
- last edited on
08-04-2026
04:57 PM
by
Content Cleaner
Unfortunately there is some delay in us Aussies getting the original DVDs sent to us, so at this stage my NI rep has burned me a copy of the main LabVIEW install but I can't find the Report Toolkit on it.
I am an SSP customer but when I go to the Services Resource Centre I get this message:
Access to the Services Resource Center could not be verified.
