LabVIEW 8.6 installation on Windows 7 and LabVIEW 11
I have TI DSK DSP boards that can only be used with LabVIEW 8.6. My computer has LabVIEW 2011; I am going to install 8.6 version on 2011 version; is this going affect any functionality of the newer version?? Also, is there any other way to interface with the TI DSK without using LabVIEW 8.6??
(3,160 Views)
Installing LabVIEW 8.6 should not affect the 2011 installation.  It should also be okay with WIndows 7.
Since I do not know what would limit you to 8.6 with the TI DSK, I can't comment on that one.
(3,153 Views)
Higher LabVIEW versions are not compatible with TI DSK 6713 (that is what i am using as DSP project target). This is the only reason I am limited to using 8.6; if there is any other alternative, I would love it!
(3,146 Views)
Accepted by 5m5
Unfortunately the latest DSP module version available is the one compatible with LabVIEW 8.6, as you can see here and here.
Alejandro C. | National Instruments
(3,109 Views)
Thanks guys! I am trying something to solve this problem; i will post soon!
(3,095 Views)
