LabVIEW FPGA: The compilation failed due to a xilinx error
I'm getting a "Compilation failed due to Xilinx error" trying to compile code in LabVIEW 2013.The code had compilated successfully in labview2012. Any suggestions on what is causing this issue?
Details:
ERROR:HDLCompiler:432 - "C:\NIFPGA\jobs\THY4t7n_z6im2K7\NiFpgaAG_0000003a_SequenceFrame.vhd" Line 29: Formal <cparametersignal> has no actual or default value.
INFO:HDLCompiler:1408 - "C:\NIFPGA\jobs\THY4t7n_z6im2K7\NiFpgaSetOutputDataEnable.vhd" Line 37. cparametersignal is declared here
ERROR:HDLCompiler:854 - "C:\NIFPGA\jobs\THY4t7n_z6im2K7\NiFpgaAG_0000003a_SequenceFrame.vhd" Line 21: Unit <vhdl_labview> ignored due to previous errors.
VHDL file C:\NIFPGA\jobs\THY4t7n_z6im2K7\NiFpgaAG_0000003a_SequenceFrame.vhd ignored due to errors
Total memory usage is 204688 kilobytes
Number of errors : 2 ( 0 filtered)
Number of warnings : 4 ( 0 filtered)
Number of infos : 0 ( 0 filtered)
Process "Synthesize - XST" failed
Compilation Time
Date submitted: 2014/2/26 18:15
Date results were retrieved: 2014/2/26 18:17
Time waiting in queue: 00:06
Time compiling: 02:02
- PlanAhead: 01:16
- Core Generator: 00:00
- Synthesis - Xst: 00:35
Message 1 of 10
(7,613 Views)
I have got the same error, Have you solved this error?
What you have done?
Details:
Compilation Time
- PlanAhead: 01:16
Mahran
Message 2 of 10
(7,406 Views)
no,the error always appear. Smiley Sad
Message 3 of 10
(7,390 Views)
Accepted by jasonneu
Hi Guys
I believe I can give you a hand on this.
I have the same problem when I am working on the Tutorial(2013) Exercise 2 with Rio Evaluation Kit.
You can try one of the following option.
Solution 1.
1. In the VI Package Manager
Select 'Tools'->'Options'->'General'->'Package Installation'->Unchecked 'Mass Compile VIs After Package Installation'
Solution 2
1. In the VI Package Manager, uninstall LCD Driver
2. Unchecked 'Mass Compile VIs After Package Installation' (See Solution 1)
3. Reinstall LCD Driver.
Mine was done after Solution 2 and the compiler works.
Hope it will be helpful to your guys.
Thank you
Message 4 of 10
(7,369 Views)
Thank you for your help, I will try to do that, but I would keen to know what is the main cause of this error?
Message 5 of 10
(7,358 Views)
What is the VI Package Manager??
I use Labview FPGA
Message 6 of 10
(7,355 Views)
Hi MSQ266
I don't know what is the main cause to it exactly.
Because I reach  the conclusion from different sources in different language like Japanese and Spanish...
Please refer to the following link.
http://www.ni.com/gate/gb/GB_EVALTLKTLCDCHAR/US
Following the step in the link
1. Download the VI Package Manager
2. Uncheck the Mass Compile VIs After Package Installation
3. Download the LCD driver
4. Install LCD driver via VI Package Manager
5. Go compile again
Hope it will answer your question.
Message 7 of 10
(7,332 Views)
thank you very much.
Message 8 of 10
(7,314 Views)
Hi!
I think I have the same error, but I've tried the solution that you've indicated and it didn't work.
I'm using cRIO-9068 with the i2c fpga host project example of the api i2c&spi. Could you help me?
This is the error:
LabVIEW FPGA:  The compilation failed due to a xilinx error.
Details:
ERROR:HDLCompiler:432 - "C:\NIFPGA\jobs\v5VU5F1_hkzQj0q\NiFpgaAG_0000003b_SequenceFrame.vhd" Line 31: Formal <ceioparameter0signal> has no actual or default value.
INFO:HDLCompiler:1408 - "C:\NIFPGA\jobs\v5VU5F1_hkzQj0q\Crio9402SetOutputData.vhd" Line 99. ceioparameter0signal is declared here
ERROR:HDLCompiler:854 - "C:\NIFPGA\jobs\v5VU5F1_hkzQj0q\NiFpgaAG_0000003b_SequenceFrame.vhd" Line 23: Unit <vhdl_labview> ignored due to previous errors.
VHDL file C:\NIFPGA\jobs\v5VU5F1_hkzQj0q\NiFpgaAG_0000003b_SequenceFrame.vhd ignored due to errors
Total memory usage is 197032 kilobytes
Number of warnings :    6 (   0 filtered)
Message 9 of 10
(6,853 Views)
i got the same problem but managed to resolve it by mass-compiling the whole VIs. Turns out, got error (which previously there is no error). Then fix the error by updating the FPGA Property Node that needs to be refreshed.
LV2013
Certified LabVIEW Developer (CLD)
Certified TestStand Developer (CTD)
Using LabVIEW 8.5.1 (2008) to LabVIEW 2024
Message 10 of 10
(6,728 Views)
