‎02-26-2014 05:20 AM
I'm getting a "Compilation failed due to Xilinx error" trying to compile code in LabVIEW 2013.The code had compilated successfully in labview2012. Any suggestions on what is causing this issue?
Details:
ERROR:HDLCompiler:432 - "C:\NIFPGA\jobs\THY4t7n_z6im2K7\NiFpgaAG_0000003a_SequenceFrame.vhd" Line 29: Formal <cparametersignal> has no actual or default value.
INFO:HDLCompiler:1408 - "C:\NIFPGA\jobs\THY4t7n_z6im2K7\NiFpgaSetOutputDataEnable.vhd" Line 37. cparametersignal is declared here
ERROR:HDLCompiler:854 - "C:\NIFPGA\jobs\THY4t7n_z6im2K7\NiFpgaAG_0000003a_SequenceFrame.vhd" Line 21: Unit <vhdl_labview> ignored due to previous errors.
VHDL file C:\NIFPGA\jobs\THY4t7n_z6im2K7\NiFpgaAG_0000003a_SequenceFrame.vhd ignored due to errors
Total memory usage is 204688 kilobytes
Number of errors : 2 ( 0 filtered)
Number of warnings : 4 ( 0 filtered)
Number of infos : 0 ( 0 filtered)
Process "Synthesize - XST" failed
Compilation Time
Date submitted: 2014/2/26 18:15
Date results were retrieved: 2014/2/26 18:17
Time waiting in queue: 00:06
Time compiling: 02:02
- PlanAhead: 01:16
- Core Generator: 00:00
- Synthesis - Xst: 00:35
Solved! Go to Solution.
‎04-06-2014 09:13 PM
I have got the same error, Have you solved this error?
What you have done?
Details:
-->Total memory usage is 204688 kilobytes
Compilation Time
- PlanAhead: 01:16
Mahran
‎04-07-2014 06:22 AM
no,the error always appear. ![]()
‎04-07-2014 02:52 PM
Hi Guys
I believe I can give you a hand on this.
I have the same problem when I am working on the Tutorial(2013) Exercise 2 with Rio Evaluation Kit.
You can try one of the following option.
Solution 1.
1. In the VI Package Manager
Select 'Tools'->'Options'->'General'->'Package Installation'->Unchecked 'Mass Compile VIs After Package Installation'
Solution 2
1. In the VI Package Manager, uninstall LCD Driver
2. Unchecked 'Mass Compile VIs After Package Installation' (See Solution 1)
3. Reinstall LCD Driver.
Mine was done after Solution 2 and the compiler works.
Hope it will be helpful to your guys.
Thank you
‎04-07-2014 05:20 PM
Thank you for your help, I will try to do that, but I would keen to know what is the main cause of this error?
‎04-07-2014 05:28 PM - edited ‎04-07-2014 05:33 PM
What is the VI Package Manager??
I use Labview FPGA
‎04-07-2014 06:38 PM - edited ‎04-07-2014 06:39 PM
Hi MSQ266
I don't know what is the main cause to it exactly.
Because I reach the conclusion from different sources in different language like Japanese and Spanish...
Please refer to the following link.
http://www.ni.com/gate/gb/GB_EVALTLKTLCDCHAR/US
Following the step in the link
1. Download the VI Package Manager
2. Uncheck the Mass Compile VIs After Package Installation
3. Download the LCD driver
4. Install LCD driver via VI Package Manager
5. Go compile again
Hope it will answer your question.
‎04-08-2014 01:14 AM
thank you very much.
‎12-16-2014 08:53 AM
Hi!
I think I have the same error, but I've tried the solution that you've indicated and it didn't work.
I'm using cRIO-9068 with the i2c fpga host project example of the api i2c&spi. Could you help me?
This is the error:
LabVIEW FPGA: The compilation failed due to a xilinx error.
Details:
ERROR:HDLCompiler:432 - "C:\NIFPGA\jobs\v5VU5F1_hkzQj0q\NiFpgaAG_0000003b_SequenceFrame.vhd" Line 31: Formal <ceioparameter0signal> has no actual or default value.
INFO:HDLCompiler:1408 - "C:\NIFPGA\jobs\v5VU5F1_hkzQj0q\Crio9402SetOutputData.vhd" Line 99. ceioparameter0signal is declared here
ERROR:HDLCompiler:854 - "C:\NIFPGA\jobs\v5VU5F1_hkzQj0q\NiFpgaAG_0000003b_SequenceFrame.vhd" Line 23: Unit <vhdl_labview> ignored due to previous errors.
VHDL file C:\NIFPGA\jobs\v5VU5F1_hkzQj0q\NiFpgaAG_0000003b_SequenceFrame.vhd ignored due to errors
Total memory usage is 197032 kilobytes
Number of warnings : 6 ( 0 filtered)
‎01-26-2015 02:08 AM
i got the same problem but managed to resolve it by mass-compiling the whole VIs. Turns out, got error (which previously there is no error). Then fix the error by updating the FPGA Property Node that needs to be refreshed.
LV2013
