LabVIEW OOP Self-Paced Training Question, Section 3-4
Hi All,
Does anyone have an example of the "Challenge" VI we are supposed to create in the OOP training, section 3-4, "Dynamic Dispatch Tester.vi:"
"Create a VI that builds an array of Sounds using Generate Tone, Generate Silence, and so on, and then dynamically dispatches Generate Waveforms.vi to create a single waveform graph that contains the sounds that you configured." "Save the VI as Dynamic Dispatch Tester.vi"
I cannot download any software through my company's firewall, so if you could just post an image of the block diagram, that would be helpful.
Thanks!
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(3,013 Views)
Accepted by diarmaede
I found an example.
Forbes Black
(2,994 Views)
To help future readers, could you point us to this example?
(2,951 Views)
When you extract the zip files from the NI download, the vi is located here:
...\2012_OOP Exercises_Solutions\SolutionSource\Exercise 3-4 Challenge\Sound Demo Support Files\Dynamic Dispatch Tester.vi
Forbes Black
(2,939 Views)
