LabVIEW SQL Get latest data from tables
Problem:
Say I have N buildings where each building:
  • Has one Humidity sensor
  • Consists of M=(between 1 and 5) Sectors
  • Each Sector has 1 Temperature sensor
Right now each building periodically logs data into three tables in a SQL server
Table 1: Contains 1 entry for each building ID, Name will never change, CalDate is updated periodically.
Building_ID          Building_Name          Building_CalDate
[I32]                      [String]                       [Date/Time]
123                       Main Office                1/9/2018 4:14:32 AM
456                       Security                     1/8/2018 5:16:15 AM
Table 2: Contains Humidity data, each new data point is appended to the end of the list
Humidity_Date              Building_ID          Humidity
[Date/Time]                   [I32]                      [DBL]
1/9/2018 4:14:32 AM    123                       15.23
1/9/2018 4:15:12 AM    456                       20.28
1/9/2018 4:15:32 AM    123                       15.50
Table 3: Contains Temperature data with Sector log, each new data point is appended to the end of the list
Temp_Date                   Building_ID          Sector_ID          Temperature
[Date/Time]                   [I32]                      [I32]                   [DBL]
1/9/2018 4:14:31 AM    456                       0                        20.23
1/9/2018 4:15:14 AM    123                       1                        35.23
1/9/2018 4:16:21 AM    123                       0                        15.23
1/9/2018 4:15:45 AM    123                       2                        25.23
1/9/2018 4:16:21 AM    456                       0                        25.23
1/9/2018 4:16:59 AM    123                       1                        35.23
I want to write a vi where the user can view this data in two formats as 2D Array with the latest measurement info like so:
Desired ResultDesired Result
Right now, I've got this as my Vi that displays all data on each table,
CurrentVi.PNGI understand from other forums that I need to put something equivalent to
select t.Building_ID, t.Humidity_Date, t.Humidity
from Humidity t
inner join (
    select username, max(Humidity_Date) as MaxHumidity_Date
    from MyTable
    group by Building_ID
) tm on t.Building_ID = tm.Building_ID and t.Humidity_Date = tm.MaxHumidity_Date
for each table, but I'm not sure how to implement that in LabVIEW
(3,031 Views)
Use the "DB Tools Execute Query" VI on the advanced menu to execute a custom query.
aputman
(3,010 Views)
