LabVIEW control TTI PL303-P power supply
I have searched entire LabVIEW forum on how to program LabView to control TTI PL303-P power supply to no avail.
May I request program; vi LabVIEW to control TTI PL303-P power supply voltage and current via USB cable.
Attached are screenshots.
Message 1 of 32
(5,948 Views)
Hi Evans,
Well, you should ask the TTI support for such a tool. Did you?
Did you even tried to look for such drivers at the manufacturer website? With some little google-foo I found this one (look for "Resources")…
Message 2 of 32
(5,924 Views)
Hi GerdW,
I already downloaded all 3 drivers:
New PL-P series Power Supplies, IVI Driver V1.6.0 - (ZIP / English) info icon
PL-P series Power Supplies combined LabVIEW Driver and LabWindows CVI Driver V1.6.0 - (ZIP / English) info icon
USB Driver V2.07 - (ZIP / English) info icon
I could not get it work on LabVIEW vi.
May I request the program vi?
Message 3 of 32
(5,918 Views)
Hi Evans,
I would install the "USB Driver" and the "LabVIEW driver".
After doing so you should find some VIs in your functions palette dedicated to drive/command the device.
And what's the exact problem? What does not work?
Do you get any error numbers from the LabVIEW driver VIs?
Message 4 of 32
(5,916 Views)
Hi GerdW,
I am not in my work area now. I will take a screenshot and show it to you tomorrow.
Message 5 of 32
(5,912 Views)
I already download "USB Driver" and the "LabVIEW driver".
Attached is missing PL303-P in function palette.
Message 6 of 32
(5,902 Views)
I have checked Device Manager.
Code 28.
Attached is Device Manager screenshot.
Message 7 of 32
(5,900 Views)
Hi Evans,
Did you also install them?
Message 8 of 32
(5,896 Views)
Certainly, TTI installation has completed.
Message 9 of 32
(5,892 Views)
Hi Evans,
and what about that USB driver? I guess that's the part your device manager is looking for…
On that LabVIEW driver: did you look in the user.lib for the driver functions? Did you restart LabView (just to be sure)?
Message 10 of 32
(5,890 Views)
