LabVIEW control TTI PL303-P power supply
There is no installation file in USB Driver V2.07. I do not know how to proceed with installing USB Driver V2.07.
"Did you restart LabView (just to be sure)?"
I definitely did, multiple times just to confirm.
"did you look in the user.lib for the driver functions?"
I have searched under "Find Instrument Driver", to no avail.
Attached is screenshot.
Message 11 of 32
(2,697 Views)
Hi Evans,
There is a PDF in the ZIP file describing the installation process.
And there is a INF file, which is the "definition" for the driver installation!
(Main point: in the device manager you can search for device drivers. Just select the INF file here! Did you ever needed to install hardware on a WindowsPC?)
Message 12 of 32
(2,685 Views)
Device Manager recognized TTI PL303-P!
Message 13 of 32
(2,682 Views)
Hi Evans,
then all you need to do is to look for the installed LabVIEW driver.
I would use the (Windows) Explorer to do so…
Message 14 of 32
(2,679 Views)
"then all you need to do is to look for the installed LabVIEW driver."
What kind of LabVIEW driver, examples?
I will use (Windows) Explorer.
Message 15 of 32
(2,675 Views)
Hi Evans,
i talk about the "LabVIEW driver", where you should that images claiming "no software will be installed"…
There have to be some VIs, most probably in a folder named "TTI" or "PL-P" or similar!
Message 16 of 32
(2,686 Views)
I am not in my work area now. I will check on Monday.
Message 17 of 32
(2,678 Views)
No search result found related to "TTI" or "PL-P" in National instrument folder.
Nothing happened after double clicking NI Instrument Driver Finder > PL303-P.
I noticed PL303-P remote indicator changed to orange. Turning the voltage knob did not change the voltage values. It is in remote function.
Attached are the screenshot of Driver files and PL303-P orange remote indicator.
Message 18 of 32
(2,668 Views)
UPDATE: LabVIEW successfully control PL303-P power supply voltage via USB. Example, LabVIEW input 5V, PL303-P power supply voltage changes to 5V accordingly.
Credits to "" and "pericles"!!
Message 19 of 32
(2,654 Views)
Message 20 of 32
(2,651 Views)
