LabVIEW control TTI PL303-P power supply
Hi Evans,
No, I can't.
There should be one in the LabVIEW driver for your device.
If there is no such VI: read the programming manual of your device, create a copy of a similar VI of the driver and adapt it according to the commands of your manual. (That's the usual way to extend such device drivers.)
Message 21 of 32
(2,237 Views)
I downloaded official PL303-P vi examples. Why am I facing these errors?
Attached is PL303-P vi errors screenshot.
Message 22 of 32
(2,222 Views)
Hi Evans,
Don't know. You should just check one of those subVIs!
When you mark one of the subVIs in the error list you should get the details of the error in the subVI. Unfortunately you didn't do this before creatingyour screenshot…
Did you install the device driver as intended (in the correct folder)?
Message 23 of 32
(2,220 Views)
Attached is the PLP error screenshot.
Default directory.
C:\Program Files\IVI Foundation\VISA\Win64\PLP\
C:\Program Files\National Instruments\
Message 24 of 32
(2,217 Views)
Hi Evans,
the DLL is missing or not within the search path for DLLs…
(Or you are using a 64bit version of LabVIEW trying to call a 32bit DLL…)
Message 25 of 32
(2,215 Views)
How do I resolve this?
Message 26 of 32
(2,211 Views)
Hi Evans,
use the 32bit version of LabVIEW to interact with 32bit DLLs…
Are you using LabVIEW-64bit? If yes: why? Is there a specific reason?
Message 27 of 32
(2,208 Views)
Yes, I am using LabVIEW 64 bits. No specific reason. The LabVIEW download link was 64 bits.
Is downloading LabVIEW 32 bits the only way to resolve the issue?
Message 28 of 32
(2,204 Views)
Hi Evans,
according to Microsoft it's the most easiest way…
Message 29 of 32
(2,198 Views)
Hi Evans,
Can you share with me the vi samples?
I cant get my PL303 to work either.
Thanks.
Message 30 of 32
(2,159 Views)
