LabVIEW indicator
How do I increase the size of an indicator vertically? (I only get the option to increase its width)
(4,648 Views)
For numeric indicators, it is a function of the font size.  So enlarge the font.
You might also be able to right click on it and Customize by editing the various parts that make up the indicator.
(4,641 Views)
Numeric indicators are typically single line (but there are exceptions) and the control height is determined by the font size as has been mentioned.
If you want an indicator of arbitrary height, use a string indicator and display a formatted value of the numeric.
(4,621 Views)
The height of the box increases using font, but the numbers displayed are still the same size. Is there any way that can be changed? I need the data to be displayed bigger-worst case scenario, can I hook it up to an external digital display and display it there physically?
(4,605 Views)
Accepted by topic author SNIreaPER
What are you talking about?  If you make the font larger, then the font gets LARGER.
Example_VI_FP
Of course you can hook up some external display if that makes sense for your situation.  But it sounds like overkill considering your original question was how to make the numeric box larger on your front panel.
(4,600 Views)
Property node. Text.fontsize
(4,599 Views)
The font can be any size. Try again.
(4,594 Views)
