LabVIEW installer size, and issues
First, thanks to all for the feedback.
I must say, some of the replies were not as polished as others... but regardless, thank you.
As an example, why not use a DVD? Why limit yourself to a 210M CD? why not use a flash drive? these are indeed solutions, I agree. However, in my case I'm limited to the use of a 210M CD.
Cheers!
Message 11 of 19
(2,579 Views)
No.  The question is "WHY ARE YOU LIMITED TO 210 MB?"  You say you have a CD, but CD's hold about 700 MB.
If we know the reason for that, then maybe it helps determine if that can be worked around, or if there are other alternatives.
Message 12 of 19
(2,564 Views)
Why am I limited to a 210M CD? customer requirements.... and as you know, the customer is always right (not always, but the idea is to keep them happy). And to be honest, at this point I do not know why they want to stick to a 210M CD.
I'll be pushing for a bigger CD size, although, the post by Sam_Sharp seems interesting.
Cheers
Message 13 of 19
(2,557 Views)
Not if the installation media you want to use is a non-standard CD. The mini CDs that come with many devices (containing driver/manuals) are 210MB in capacity. Business card CDs are even less.
(blog)
Message 14 of 19
(2,551 Views)
Okay.  So you are talking about those mini CD's.  LIke the ones that get handed out at tradeshows like business cards?
That makes sense why they are so small in size and thus capacity then.
If that is being forced on you as a requirement, you will either struggle to find a way to minimize the installation size of the drivers and your executable itself to the bare minimum you need, (and some of the links that the others gave might help), or you just won't be able to do it and you'll have to force them into another options,  (like using an ordinary CD.)
One other possibility is do you need to do it in the latest version of LabVIEW.  Drivers and installs tend to grow a little bit with each version.  If you are able to drop back a few versions on LabVIEW and the corresponding drivers that you need, but still new enough to support the latest PC OS's, maybe the installation size gets to be just small enough to fit.
Message 15 of 19
(2,527 Views)
Take a look at the attached "experiement results"....
Message 16 of 19
(2,476 Views)
It looks like your best situation would be to back save your VI's to LV 2011 and build an .exe and installer from that.
Message 17 of 19
(2,468 Views)
Success, success, sucess!
I was able to get my HelloWorld.vi (6K) installer from 225M down to 40M! and the program runs directly from the CD!
Cheers!
Message 18 of 19
(2,442 Views)
Thanks to Sam_Sharp for your post, and thank you fomine for the help
Message 19 of 19
(2,437 Views)
