LabVIEW load error code 3: Could not load front panel
Dear all,
I have a same problem. If I want open .vi it was ok. But if i open by .exe there is an error: "LabVIEW load error code 3: Could not load front panel". I'm using LabVIEW 2019. I tried add connPaneRecoveryMode=True to .ini , but it is not working to me. Could somebody help me and recover attached VI, please?
Best Regards
Message 171 of 176
(2,340 Views)
Hi Jie,
here you go (opening in LV2020 and downconverted back to LV2019)…
Message 172 of 176
(2,332 Views)
Thanks GerdW,
Did me a great service, thanks a lot!
Best Regards
Jie
Message 173 of 176
(2,321 Views)
Hi everyone,
I have a same problem. If I want open .vi there is an error: "LabVIEW load error code 3: Could not load front panel".
I'm using LabVIEW 2011. I tried add connPaneRecoveryMode=True to .ini , but it is not working to me. Unfortunately I have no previous versions and no SCC in the lab computers.
Message 174 of 176
(2,231 Views)
No luck with LabVIEW2016 either.
Do you know the German phrase "Kein Backup, kein Mitleid!"?
Message 175 of 176
(2,210 Views)
Thank you very much for your effort GerdW.
Message 176 of 176
(2,176 Views)
