LabVIEW proverbs!
--- Run Continuously is no way to Run a VI ---
(from here)
Message 221 of 305
(4,243 Views)
After reading this post by Jeff I suspect he has been studying at the Rolf Kalbermatter School of Understaements as evidenced by the quote;
And having a 100 second long event case is not really a good idea.
Ben
Message 222 of 305
(4,173 Views)
OK Ben
Ben
To make proverbs 55:223 official (And run that 55 through Roman numerals)
"The wise LV developer passes commands to actors out of user events while the fool only pounds his unresponsive mouse up and down."
Message 223 of 305
(4,135 Views)
@Ben wrote:
When in C point. When in LV, wire.
 In a thread discussing In-Place Element Structures​, References and Pointers, Compiler Optimizati​on, and General Stupidity.
Jim
Message 224 of 305
(4,069 Views)
USE 'Timing' as a JUICE to a thirsty(greedy) loop!!! 🙂
Thanks as kudos only:)
Message 225 of 305
(4,058 Views)
I'll offer one that I have handed out a few times:
enum + variant = class hierarchy
identifier string + variant = class hierarchy
enum + flattened data string = class hierarchy
identifier string + flattened data string = class hierarchy
Or, more simply:
type identifier + generic data container = class hierarchy
And "Always buddy your code."
Message 226 of 305
(4,057 Views)
Aristos was inspiring me with his ID...
Please notify the consumer if the cashier's queue slows down...
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
Message 227 of 305
(4,034 Views)
One more, this one courtesy of Kurt Grice: "The Object is the Message."
Message 228 of 305
(3,995 Views)
From Jeff in this message.
"When your executable can get a driver's license, it's obsolete."
Message 229 of 305
(3,848 Views)
Message 230 of 305
(3,791 Views)
