LabVIEW to Raspberry Pi - failed to deploy target settings,Deployment completed with errors.
I'm using LabVIEW 2020 Beta with Raspberry Pi 4. Following the tutorial setup everything is OK.
First time build application and deploying to Raspberry Pi 4 was successful.
But i try to edit some content and online again it pop window below:
After press "OK", it come out the error below :
After this it become disconnect until reboot the Raspberry Pi 4. And then the looping this error again and again😓
Did you guy facing the same problem? or just me facing this problem, looking for solution. Thanks.
(5,256 Views)
Why are you still using the beta?  Download the release version.
Bill
CLD
(Mid-Level minion.)
(5,202 Views)
Sorry for misunderstanding, is LabVIEW 2020 Community edition.
(5,178 Views)
Did you ever solve this issue?  I'm having the same problem
(5,077 Views)
Not yet, still looking for solution.
(5,069 Views)
I am having the exact same problem. Did you ever find a solution?
(4,860 Views)
Accepted by topic author Keele
Check for my answer in this post, this should work...
https://forums.ni.com/t5/LINX/Failed-to-deploy-target-settings/m-p/4102682#M270
(4,573 Views)
