LabVIEW2019 - case structure with wired error cluster changes behaviour!!!
I try to get used to it Smiley LOL
After all these years I give it a chance.
Greets, Dave
Message 11 of 14
(1,458 Views)
You did expose a bug - you should get an award for that one.  😉
Bill
CLD
(Mid-Level minion.)
Message 12 of 14
(1,441 Views)
Hello Dave
Would you mind to explain if my code (Image attached) has broken error cluster? I am newbie and I have to kind of recreate this code which in my case has shown this broken ERROR CLUSTER.
Also, if it may cause ERROR-1073807346 which corresponds to COM PORT initialization.
Message 13 of 14
(1,163 Views)
@DeeQue wrote:
Hello Dave
This is a 4 year old thread that has already been marked as solved.  It also has nothing to do with your problem.
You will get much better results if you start a new thread, and you should also post the entire VI file, not a screenshot of it.
Message 14 of 14
(1,155 Views)
