LabVIEWCLI error 1130
I'm trying to use LabVIEWCLI for automated building of packed libraries. For most (smaller projects) it runs fine, but for few large projects it constantly returns this error:
Error code : 1130
Error message : Call By Reference in RunExecuteOperationVI.vi->RunOperationCore.vi->RunOperation.vi->RunOperation.vi.ProxyCaller
An error occurred while running the LabVIEW CLI.
After the error, the LabVEIW process hangs and I have to kill it.
The project is error free, I can build directly from project, the error is only when using CLI.
I tried increase timeout values in C:\Program Files (x86)\National Instruments\Shared\LabVIEW CLI\LabVIEWCLI.ini doesn't help.
I tried both LV2016 64b and LV2018 64b same results.
The project contains mix of classes and VIs, some of them are from different packed libraries. I think it has to do something with amount of VIs in library, when removed about half of VIs the build passed.
Message 1 of 16
(7,797 Views)
Accepted by petrz
This issue is related to CAR# 705294 which is being evaluated by R&D.
Message 2 of 16
(7,729 Views)
Thanks for looking into this issue.
We are also seeing this and are in the process of making decisions that are being impacted by this issue. I was wondering if there are any updates around a potential resolution, or timeline to a resolution. Alternatively, could you recommend a resource for keeping track of an issue's status, or where to find more information about CAR# 705294?
Thank you very much!
Christopher
Message 3 of 16
(7,625 Views)
I am also encountering the same issue. Any update on the status of CAR# 705294?
Amrit
Message 4 of 16
(7,615 Views)
I don't have any new information and I don't know about a way how to track CAR. NI told me it should be released in next service pack.
Message 5 of 16
(7,595 Views)
In the documentation on the f2 patch for LabVIEW 2018 it is not mentioned, so therefore it should be still present.
https://www.ni.com/en/support/documentation/supplemental/18/labview-2018-patch-details.html
Message 6 of 16
(7,586 Views)
Thank you petrz and aptivo for the info. Of course it'd be nice to have a timeline, but that's probably only something NI staff could provide. Does anyone have an idea how often service packs are released (ex. monthly, totally random, quarterly)?
Thanks again!
Christopher
Message 7 of 16
(7,575 Views)
I have struggled with the same problem for few days before I found this topic.
Is there an workaround available? Where I can check status of this CAR on NI website?
Message 8 of 16
(7,532 Views)
I was able to get in touch with NI Support. They mentioned that the issue is being worked on by R&D but the latest changes can be downloaded from GitHub (https://github.com/JamesMc86/LabVIEW-CLI/releases). Looking at the changes in version 2.0.0, there is a better error handling on the TCP process which should fix the issue in question.
Message 9 of 16
(7,523 Views)
Awesome! This is great news, I'll test this new version out as soon as time permits. Just having a link to the github page for the CLI is priceless 😄
Thanks @amritnagi!
Message 10 of 16
(7,521 Views)
