LabView 8.6 and NI-Scope 4.0 will not work together
I have LabView 8.6 running on a PXI system and am trying to acquire data from a PXI-5105 digitizer.  I was previously running LabView 8.2 and an older version of NI-Scope.  I switched over to LV 8.6 and also NI-Scope 4.0 and now I cannot use NI-Scope in my VI's.  It has me look for the file type for every NI-scope component that I use in my VI and is looking for the .clt files.  I can still use NI-Scope soft panel but it will not show up under the measurement tab like before.
(2,530 Views)
Accepted by Roysendo2013
NI-SCOPE Compatibility with LabVIEW
You need an older version of NI-Scope or a newer version of LabVIEW.
(2,515 Views)
Thank You.
(2,510 Views)
