LabView Crashes When Editing Block Diagram
When least expected and usually at the most inopportune times the LabView 8.6.1 development environment crashes when I am editing my block diagram. It usually happens when I am moving VI's or wires using the arrow keys. This has happened to me several times. Is anyone else having this problem? Is there a bug fix out there?   Attached are some of the windows error logs
(3,501 Views)
There is a known issue with LabVIEW running out of memory slots in it's image table
http://zone.ni.com/devzone/cda/tut/p/id/7324#36543_by_category
I have experienced this issue first hand and it does make LV very unstable with crashes at the most inopportune times.
Try uninstalling those toolkits and drivers that you are not currently using. In my case 8.6.1 became completely stable after that.
Greg Sussman
Sr Business Manager A/D/G BU
(3,475 Views)
http://forums.ni.com/ni/board/message?board.id=170&message.id=359839#M359839
I had a problem that the "magic control" in this thread resolved.
Jim
(3,449 Views)
This was reported to R&D (#131931) for further investigation.
What we have noticed is the larger the block diagram the more likely this error will occur.  The best way to prevent this error from happening would be to reduce the size of your block diagram by implementing subVIs as much as possible.
Jon S.
LabVIEW NXG Product Owner
(3,422 Views)
