LabView oldest version (2019) for Win 7
I have a valid license, but it does not allow me to download LabView 2019.
(5,352 Views)
I did a Web search for "LabVIEW Windows compatibility", and found two sites, a recent one that seemed to suggest that Windows 7 would run LabVIEW 2019.  Another (archived) "As of 2011, all new versions of NI software will document their compatibility with Windows 7 64-bit and LabVIEW 64-bit in their Readme files. If there is any question about the compatibility of a piece of software with the 64-bit versions of Windows and LabVIEW, please refer to the Readme for that release."  Not so helpful, which may explain why it is archived (= obsolete?).
I'm less surprised that you cannot download and install LabVIEW 2019 on Windows 7.  NIPM, the LabVIEW Software Installer (and still not working 100% of the time) was introduced with LabVIEW 2017, and if it cannot install on Windows 7 (which seems, to me, likely), then you can't install LabVIEW.  This, however, is just a "guess".
I don't know (because I've not tried to do this) whether or not you can build a modern (say LabVIEW 2019) LabVIEW Executable that will run on a Windows 7 PC.  You'd need, of course, a Run-Time Engine for the Windows 7 machine, and I don't know if it is possible to install the 2019 RTE on Windows 7 -- that's another question that maybe one of the Forum experts can answer.
(5,317 Views)
Doesn't this work?
https://www.ni.com/en/support/downloads/software-products/download.labview.html#305508
Qestit Systems
Certified-LabVIEW-Developer
(5,308 Views)
On this page the Download Button is activ only when I choose the newest version (2022 Q3) of LabView.
(5,298 Views)
Its grayed out because you should have valid subscription as stated here:
Screenshot 2022-12-19 175210.pngScreenshot 2022-12-19 175210.pngIn general you have four different possibilities:
1. Try to register your LabVIEW with serial number under My Products, and then may be this button will be available.
or
2. Download and install NI Package Manager (if not installed yet), start it and try to install from here (sorry I have German Screenshot only):
or
3. try to install from command line
>cd C:\Program Files\National Instruments\NI Package Manager
>NIPackageManager.exe install ni-labview-2019-core-en --temp-feeds=https://download.ni.com/support/nipkg/products/ni-l/ni-labview-2019/19.1/released
or
4. try to download from direct link https://download.ni.com/support/nipkg/products/ni-l/ni-labview-2019/19.1/offline/ni-labview-2019_19....
if none above works for you, try to contact local NI representatives.
(5,247 Views)
Thank you guys, I try it.
(5,244 Views)
I still have a small computer running at Windows 7.
The executable I create for that computer is created with LV 2020. That runs on W7.
Kees
(5,213 Views)
