Labiew wire is very slow
Thanks @gerd and @thols
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 27
(1,333 Views)
If you haven't tried this already, try creating a brand new VI and pasting the contents of the offending VI into the new one.
Patrick Allen: FunctionalityUnlimited.ca
Message 22 of 27
(1,316 Views)
Just to clarify a bit, that means the block diagram contents, not the front panel!
Bill
CLD
(Mid-Level minion.)
Message 23 of 27
(1,308 Views)
hey Crossrulz,
You are right,so the code goes to 7.4, the code in't quite complex but yes, quite a lot of duplicated code which unfortunately i cannot find out a way to avoid that duplicate right now,
I tried to decrease the limit but seems no obvious change.
That pretty frustrating
Eric
Message 24 of 27
(1,284 Views)
I actually tried to delete some VI and i can see the slow problem can be avoid significantly.
that's say it is a problem with my code structures,
but all my other if case have almost the same structure as i posted in the first page,
there is no several layer vi in those two if case
Message 25 of 27
(1,282 Views)
@ericyuan wrote:
hey Crossrulz,
Step one would be to create a sub-vi of that code so you only have a few instances of a vi.
/Y
Qestit Systems
Message 26 of 27
(1,258 Views)
Accepted by topic author ericyuan
2 options:
1. For things that are the same in every case of a Case Structure, it should be moved to be outside of the case structure.
2. Other random duplicate code should be turned into a subVI which you can call from many places.
Both of those will help reduce your complexity.
Message 27 of 27
(1,235 Views)
